Help can you adjust FSE boost valves
Old Nov 3, 2009 | 12:17 AM
leeboy_09's Avatar
leeboy_09
Default Help can you adjust FSE boost valves
Hi dont know too much about them but the escorts got one on, can these be adjusted? if so how and why would you adjust it? would changing / adjusting this improve my idle problem? does anybody else have one fitted do they make a massive difference, cheers lee
Old Nov 3, 2009 | 08:10 AM
Captain Cotswold's Avatar
Captain Cotswold
Chuck it in the bin. They're the touch of death for your car. Smelling a bit rich at all is it?
Old Nov 3, 2009 | 09:20 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
as above, standard ones are adjustable and won't over fuel massively under load like the fse ones.
basically for more fuel pressure, take the top nut off and you'll find a screw underneath, wind this in a bit.
in all honesty though, the rising rate is 1:1.7 so will overfuel massively on standard management, on something fully mapable it can be fine.
Old Nov 3, 2009 | 09:34 AM
Best adjustment is to the bin.
Old Nov 3, 2009 | 09:45 AM
Rollinz's Avatar
Rollinz
as above... to the bin
Old Nov 3, 2009 | 01:48 PM
leeboy_09's Avatar
leeboy_09
Are they easy enough to replace (gunna buy a standard one) is there any how tos on here, yes it does smell, its like fresh petrol is that to do with the boost valve (i didnt fit it was already on ) cheers
Old Nov 3, 2009 | 04:43 PM
Yes easy to do, unbolt old, pull out, can be very tight, then fit the new std one job done.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
Russ Payne
Sep 25, 2015 08:29 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
