Modified 2WD Sump to accept oil return from Bailey Breather
Im having a sump modified to accept the oil return from a Bailey breather tank and I was just wondering what side I should have the return on the sump fitted. Plenum or turbo side ?
Im also having an oil temp sender fitted to the sump at the same time.
Any advice or photos would be great
Im breathing from both sides of the block and returning oil to the sump, where there is no pressure to restrict the oil returning. If you speak to Bailey they in fact recomend this, but its a pain taking the sump off and having it modded, so they make do with returning the oil to the crank etc.
But, I stll want to know what side of sump to have the return running too ?
FlashRS
13
31-08-2015 06:02 PM
