4wd head on 2wd block?
hi mate
if you use a 2wd bottom end or 2wd pistons on a 4wd head you will up the compression by .3
so lays say if the 4wd head on 205 or 200 block and 2wd pistons are standard ( not been skimed or dected in any way,) the compression will be 8:3:1
same way if you use 2wd head/ on 205 or 200 block with 4wd pistons it lowers the comprssion by .3 so it will be 7:7:1
hope this helps
marco
hope this helps
marco
dojj
28
Sep 11, 2015 10:00 PM
