Focus air intake hose and ABS light
Old Apr 22, 2017 | 09:12 AM
dared20's Avatar
dared20
Question Focus air intake hose and ABS light
Been repairing my Mk1 RS and it's turning out to be more work than i expected! Front wings are off, and there are more problems underneath...
First issue: the air intake hose under the front left wheelarch -how do I find the part number for this hose as it's perished.. Also, if I get something like a Gen 2 K&N induction kit, will I not need all this hose assembly..? If so this may be better option.
Secondly: Sill plastic covers were glued on with a LOT of black mastic, is this normal, or did the previous owner do this? Should I do the same when putting it back?
Thirdly: I reconditioned all the rear end brake bits (callipers stripped and painted, new discs, flexi and fixed hoses, splash covers galvanised etc), I put new ABS cables in as well, as I may have damaged the originals taking them out of the rusted hub. ABS light will NOT go off!! I've tried replacing one side with the old cable (only have one usable now), and the other side, and taking for a spin in between, and no luck (apparently the system resets if you drive >5mph?). I've also checked that each side gets a signal from the CPU, and it blips every couple of seconds, so all good. They are after-market cables, but I wouldn't have thought they would cause me this much grief!!!
Any ideas or comments welcome to 1, 2 or 3...
Old May 29, 2017 | 07:47 PM
Mashurst's Avatar
Mashurst
You may have to re-set the code before the light goes out ? try using forscan Mate...
Old May 31, 2017 | 06:02 PM
bigdel's Avatar
bigdel
The genuine Ford intake hoses are scarily expensive these days if you buy new from Ford (£200 ish if I recall).
We have an almost new one that may be for sale (need to check with my son first) or a brand new and unused big filter and MAF relocation kit from Car Parts Express which is now surplus to requirements.
