run then misfire and dies
Old Sep 26, 2003 | 02:32 AM
RS500/364's Avatar
RS500/364
Default run then misfire and dies
right i was driving tonite and not fast at all the engine misfired and died the i stared it up and went for about a mile and misfired then died again call the rac and "cant see a problem be on your way " so drove for about 3 mile and misfired then died and that was it car turns over but will not start any ideas? crank sensor? so if i cant sort it i will break the car i am 95% sure of it
Old Sep 26, 2003 | 07:37 AM
Guinnless's Avatar
Guinnless
What car? RS500?
Ignition amp module is a favorite here.
Old Sep 26, 2003 | 10:20 AM
RS500/364's Avatar
RS500/364
O DEAR WHAT CAN I SAY SPOT ON HAD A SPARE AND THE CAR IS RUNNING NOW CHEERS ONLY TOOK 5 MINS
THE RAC TOOK 6 HOUR LAST NITE (2 CALL OUTS)
AND EVEN GOT THE WRONG TRAILER THAT COULD NOT GET THE CAR ON TO
THANKS AGAIN PASSION
Old Sep 26, 2003 | 04:13 PM
Stu @ M Developments's Avatar
PassionFords Creator
Old Sep 26, 2003 | 05:12 PM
Guinnless's Avatar
Guinnless
Glad to help
Old Sep 29, 2003 | 02:45 PM
RS500/364's Avatar
RS500/364
it playing up again but the crank sensor ant working so would that course the mis fire?
Old Sep 29, 2003 | 06:47 PM
Guinnless's Avatar
Guinnless
The crank sensor is fundamental to the ECU so yes it would cause the misfire.
Old Sep 29, 2003 | 06:56 PM
RS500/364's Avatar
RS500/364
ordered and should fit it tommorrow
Old Oct 1, 2003 | 04:03 PM
RS500/364's Avatar
RS500/364
ITS STILL PLAYING UP HELP NEW CRANK SENSOR FITTED(REV COUNTER WORK)
BUT SEC MONITOR DOE NOT READ ANY REVS
HELP
Old Oct 1, 2003 | 06:40 PM
3dr cossie's Avatar
3dr cossie
my three door cossie had similiar problems, ford garage told me there was dampness in the dizzy and so loose wires in the engine compartment, if that helps
Old Oct 1, 2003 | 08:10 PM
Guinnless's Avatar
Guinnless
Have you gapped the crank (0.6-1.0mm) and phase sensor (02.-0.3mm)? Plug type and gap?
Could you describe how the misfire is now?
Old Oct 2, 2003 | 01:53 AM
RS500/364's Avatar
RS500/364
when warm it happens and its a backfire
sorry i am confussed
Old Oct 2, 2003 | 12:14 PM
Guinnless's Avatar
Guinnless
A backfire
If you are not sure what I mean then you need to get it checked out by a pro who can check all the sensors for you.
Are there any decent tuners in your area?
Old Oct 2, 2003 | 05:28 PM
RS500/364's Avatar
RS500/364
its in with rally bits at the moment NO CAR AT THE MO
Old Oct 2, 2003 | 05:29 PM
RS500/364's Avatar
RS500/364
I NEED YOU TO CALL ME ABOUT THE LEATHER YOU GOT I AM UP AT J28 OF THE M1 MAYBE SUNDAY
Old Oct 2, 2003 | 07:30 PM
Guinnless's Avatar
Guinnless
Leather
I had a cloth interior for sale.
dombanks
Sep 21, 2015 08:38 PM
Eigdoog
Sep 13, 2015 05:46 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
fuzzy
Sep 4, 2015 10:11 PM
