hesitating Cossie
Old Oct 30, 2003 | 02:44 PM
Switch's Avatar
Switch
Default hesitating Cossie
MY car drives great but this little niggling prob arises every now and then. When i floor it for a short period of time then back straight off, the car feels hesitate for short period(only about 5-10 seconds) Any ideas?
Its a 2wd Saff 200 engine 8000 miles, new hybrid T3 turbo stg 1 chip, 4x4 intercooler, pipercross cone filter, scorpion exshaust.
CheeRS
Scot
Old Oct 30, 2003 | 05:08 PM
Stu @ M Developments's Avatar
PassionFords Creator
explain in more detail please, im not sure what you mean M8
Old Oct 31, 2003 | 01:09 PM
Switch's Avatar
Switch
the car drives prrrfect( except for a slight high idle) If i am cruising along at says 40mph and then just floor the accelerator, the car picks up fine, accelerates fine etc, but when i come off the throttle again to just cruise, the engine feels a little hesitant, almost as if the throttle pedel has become over sensitive to less pressure on it. ie i slow down to cruising again then if come off the accelerator a little more then car pitches and slows down alot more than it mormally would. It only lasts a short time then its fine again.
Thoughts through my my was excessive fuel flooding the engine but hey I know nufink!!
CheeRS
Scot
Old Oct 31, 2003 | 02:52 PM
Id say it was the slightly high idle actually mate... its causing excess drive on overrun.
Give it a try.
Old Oct 31, 2003 | 03:01 PM
Switch's Avatar
Switch
so how do i turn the idle down, or shall i take it to rob at scc to do it, maybe get the timing and CO etc checked at same time.
just changed plugs and oil.
CheeRS
Scot
Old Oct 31, 2003 | 04:35 PM
Give her to Rob mate.. better safe than sorry.
Changing the idle base will also change the emmissions, so best let a man with the equiptment deal with it
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
