XR2i rev counter
Old Dec 4, 2003 | 03:36 PM
Default XR2i rev counter
The aftermarket rev counter already fitted to my XR2i only reads half the revs on the dash rev counter. I have checked that the signal wire is connected correctly behind the dash and that the rev counter is switched to 4 cylinder. Any ideas why?
Need help before I destroy car!!!
Old Dec 4, 2003 | 06:29 PM
richm's Avatar
richm
presumably this is a EFI XR2i?
It uses wasted spark twin coil ignition setup - the tacho connection is from one of the coils, so only sees half as many sparks as a conventional 4-cyl distributor system.
Can you set the tacho to 2-cylinder?
Old Dec 5, 2003 | 04:48 PM
Unfortunately not. Would connecting the after market tacho signal wire to both coils work? I was thinking perhaps in parallel.
Thanks
Warren
Old Dec 5, 2003 | 06:49 PM
richm's Avatar
richm
you can't join the two coil connections together, or the ignition won't work!!
Possibly if you connected two diodes from the coil connections and then joined to the tacho..? kinda thinking aloud here..
TPM961
Jan 15, 2018 10:50 AM
Andypandy260
Sep 23, 2015 10:28 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
cozzy jeff
Aug 14, 2015 05:46 PM
