PISTON RINGS
Old Dec 13, 2003 | 03:02 PM
Default PISTON RINGS
A mate of mine is rebuilding his cossie engine and the muppet who was giving him a hand has managed to snap one of the oil rings on a piston!
does anyone know if these can be brought individually or as a set seperate from the piston rings?
he's not very happy about it and if it means a new set of rings i think the muppet helper may need to die!
Old Dec 14, 2003 | 09:37 AM
anyone
Old Dec 14, 2003 | 01:26 PM
richm's Avatar
richm
Darren, have you tried Cosworth direct?
Their YB pricelist shows piston rings individually..
http://www.cosworth.com/med/usr/754/...spdf510434.pdf
http://www.cosworth.com/med/usr/754/..._pdf957410.pdf
PA2095 STD COSWORTH 2WD PISTON (C/W PINS & CLIPS)
PR1050 TOP RING 7.50
PR1051 2ND COMP RING 5.20
PR1052 OIL RING 7.50
PA2062 STD COSWORTH 4WD PISTON 95.00
PR1051 2ND RING 5.20
PA2062+025 STD COSWORTH 4WD PISTON (+0.25) 95.00
PR1053 TOP RING 13.50
PR1054 2ND RING 5.20
PR1055 OIL RING 13.50
PA2062+050 STD COSWORTH 4WD PISTON (+050) 95.00
PR1056 TOP RING 13.50
PR1057 2ND RING 8.50
PR1058 OIL RING 13.50
HTH
Old Dec 14, 2003 | 02:43 PM
nice one! cheers rich
Old Dec 14, 2003 | 02:44 PM
richm's Avatar
richm
worst case, Cosworth or Woodford Garage will do a piston set for £80 i believe.
Old Dec 14, 2003 | 03:17 PM
yea woodford are only a 10 min drive from me but the tit who broke it has to pay for it so £13.50 would be better than £80
Nov 1, 2015 06:53 PM
deathrider666
Sep 28, 2015 06:12 PM
