noise pissing me off
Old Oct 1, 2003 | 09:00 PM
Red's Avatar
Red
Default noise pissing me off
Can someone help here please, i'm pulling me hair out. ive got a squelling noise on my engine, this what ive tried so far.
Ive replaced timing belt and tensioner
Alternator drive belt
checked for anything catching or scraping etc etc
ive run the engine with the alternator belt disconnected and it still does it, the noise itself is like a chirping rotating loud noise, like a fan belt slipping, but its not, its allot worse when the engine is hot, but only does it on light accelleration and over run, on hard accelleration and full boost no noise at all, it wont do it when stationary ether you can rev it as much as you want it wont do it at all, as soon as the car is moving it starts, i think its load related, there is no power loss and the car runs 12psi boost with or without the noise, its just friggin embarrasing as hell.
The cars a sapphire 4x4 on a J plate green top and has been stood for over a year,could it be anything on the turbo side like actuators or owt like that, its ahd a recent service as well but nothing changed there.
anything siezed that i could check that might make an noise like this you can think off, please help me its doing my head in now.....
Old Oct 2, 2003 | 12:17 PM
Guinnless's Avatar
Guinnless
Check the turbine shaft for play as it could be touching the housing.
Old Oct 2, 2003 | 07:32 PM
Red's Avatar
Red
i'm not 100% ofair with what to do here, the turbo is 3 year old but only done 5000 miles when i took the boost hose off to the air filter, the turbo blades spun freely and quitely but its nano close to the alloy housing at the edge of the blades, is this normal, and how do you check for play and is it adjustable if so how.. im a bit new to all this can you tell, so please be gentle with me......
Old Oct 3, 2003 | 12:25 AM
micky c's Avatar
micky c
it could be your camshaft bearings
Old Oct 3, 2003 | 08:56 AM
Guinnless's Avatar
Guinnless
That crossed my mind too but t wouldn't be affected by load.
Red. Wiggle the shaft about (ooeer) and see if it makes contact with the housing.
HTH
Old Oct 3, 2003 | 11:20 AM
Red's Avatar
Red
ok will try this wiggling this afternoon, is it adjustable if it does,
Old Oct 3, 2003 | 04:15 PM
Red's Avatar
Red
right been out and checked for end play there is some there, but it spins free as a bird, and quite as a mouse,and its very close to the housing, ive took some low quality footage of the noise so you can here it with specail thanks to Monte for the web space here is the link.
http://720plan.ovh.net/~passionf/for...ic.php?t=17209
its 6mb mind but please have a listen and help me cure this friggin noise as its doing my head in.
cheers Red
Old Oct 4, 2003 | 09:16 AM
dave cos4x4's Avatar
dave cos4x4
Could you not take the compressor casing off and have a look to see if it's been touching the housing etc....there should be some sort of markings if it has.
Dave.
Old Oct 4, 2003 | 08:04 PM
Red's Avatar
Red
Dave, is it much of a job taking the turbo off and taking it to bits for inspection, i dont want to end up needing one if i balls it up thats all......
Old Oct 6, 2003 | 08:58 PM
Red's Avatar
Red
i would say there is about 0.5 to 1mm of end float on the shaft, but its only done 20k miles new as well from ford.... hope it aint the turbo.
is there a dummys guide to turbo's anywhere in relation to what fits what and what all the number and specs mean, what works and what don't etc, as if its the turbo i might as well upgrade it eh, but to what is what i need to know.... help needed please
Old Oct 9, 2003 | 09:36 PM
Red's Avatar
Red
believe it or not its its fixed and you would never guess what the hell it was, i was amazed its the most unovious thing as well if you listen to the video then tell me what it sounds like, and you will never of thought it was.
THE BLOOMIN FRONT PROPSHAFT (FRONT UJ) JOINT the inner bearings were shot and it was siezed, causing the screeching noise, if you have read this and not listened to the video go back and listen to it.
Glad i did'nt get that turbo now phew
Old Oct 13, 2003 | 07:36 PM
dave cos4x4
How did you find it.
Dave.
Old Oct 13, 2003 | 09:13 PM
Red's Avatar
Red
i went to a mate garage and drove the car on a two poster ramp, with the wheels hanging and little brakes, to load up the engine and we pin pointed the area, then sent it up to confirm and the joint was siezed solid one way and floppy and full of play the other, so got them both replaced, now its mint...
gingeRS
17
Oct 2, 2015 09:42 AM
dojj
Sep 29, 2015 10:32 PM
Botts
Sep 22, 2015 02:04 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
rsturbo27
Sep 5, 2015 05:08 PM
