Wiring for a S2 RS Turbo
Old Jun 8, 2004 | 05:57 PM
davidnormanuk's Avatar
davidnormanuk
Default Wiring for a S2 RS Turbo
Hi all,
When I bought my engine and wiring etc to convert my Cabbie to a Turbo the wiring looks like its been chopped and messed around with quite a bit. Anyone know what basics I need in the wiring to get the car started. Any help on this would be appreciated.
Dave
Old Jun 10, 2004 | 04:13 PM
IANS2RST's Avatar
IANS2RST
leave the original loom in place, plug everthing in that you need on the turbo loom and separate it from the rest of the car loom, lights etc.
if you chop the turbo management loom from the main loom where the wires end at the fuse box, fuel pump relay & clocks you will have 5 wires to connect, 3 switched lives, 1 to the fuel pump relay & 1 to the rev counter.
to tidy things up what ever is left of the 3i loom that will not be used u can can then strip this out in the same way.
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Cosnada
Aug 27, 2015 09:15 AM
muz
Aug 16, 2015 12:57 PM
turbobill
Aug 1, 2015 08:55 PM
