Zetec/FRST/Cosworth Capatibility
Hi Everyone,
Hoping someone on here can help me out, as a fair few people here know their stuff. As some of you know (but i imagine most don't) i'm building a 16v Zetec Turbo Fiesta Rs Turbo, theres a picture diary on fiestaturbo.com
Well, basically, i want to run the engine in on the standard blue injectors, OFAC management, then i want to change to the SECHS S8 ecu, however i'm told that this will require the fitment of Cosworth Management, or at least the cosworth loom.
Now the problems i'm having is my car is quite a hybrid of sensors, i have the following-
Zetec Throttle Position Sensor (On the side of the 1800cc Zetec Throttle Body)
Zetec Idle Speed Control Valve
Zetec Camshaft Positioning Sensor (Not plugged into the FRST OFAC loom)
FRST Crankshaft Positioning Sensor in 1800 Zetec Housing, FRST Flywheel.
FRST Coil Pack
FRST OFAC Map Sensor
All other sensors are FRST
EEC-IV 440cc Injectors, 16 Ohm.
Basically, does anyone know whether these sensors can be used on the Cosworth loom with the Sechs Ecu, i know that i cant fire up on a Cosworth ECU due to the injectors being the wrong impedance. I'm also not sure as to what loom to go for (such as Escort/Sierra/2wd/4wd).
If anyone can offer any guidance it will be greatly appreciated.
Thanks
Matt
FRST Coil Pack
Thanks
Matt
