knocking cossie engine
Old Jun 30, 2004 | 08:23 PM
rossatom2's Avatar
rossatom2
Default knocking cossie engine
has anyone experienced a knocking tapping noise coming from the engine? it sounds a bit like the valves tapping the pistons but it aint. i replaced the whole bottom end in one go and the whole top end , set the timing up started her up and the noise is still there .
is there anything electrical that could couse the timing to be so far out that the engine sounds like a transit van? cheers for any help
Old Jul 2, 2004 | 10:33 AM
ian rst's Avatar
ian rst
Mine does this and its been re built as well. So i would like to know what it is.
Old Jul 2, 2004 | 04:24 PM
Dave Henshall's Avatar
Dave Henshall
didi u have the head skimmed? and only put back a std gasket?
the std thickneess can only really allow for up to 1 skimm beofre u need a thicker one like the cometic.
Old Jul 2, 2004 | 06:23 PM
rossatom2's Avatar
rossatom2
nope it not been skimmed at all
Old Jul 3, 2004 | 01:59 PM
Dave Henshall
have you timed it up right using the post to line up with the TDC mark on the bottom pulley and NOT the groove just behind it - very easy to do.
Old Jul 3, 2004 | 08:59 PM
rossatom2's Avatar
rossatom2
yes i timed it up proper. i starting to think it must be skimmed even though i been told otherwise
Old Jul 4, 2004 | 03:44 PM
ian rst's Avatar
ian rst
Engine advantages said to me that it could be the cam followers being worn but i am assuming yours have been replaced?
Old Jul 4, 2004 | 05:57 PM
rossatom2's Avatar
rossatom2
yes new ones used
JoeyBoyden
Jan 4, 2024 02:36 PM
Gadget
Aug 26, 2015 01:02 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
MARKYMARKONE
Aug 2, 2015 09:33 PM
lockie
Jul 31, 2015 10:03 PM
