DUMP VALVE PROBLEMS ON ESC COS
Old Jul 12, 2004 | 02:41 PM
Gerry Mac's Avatar
Gerry Mac
Default DUMP VALVE PROBLEMS ON ESC COS
CAN ANYONE HELP ME IM HAVING TROUBLE WITH TRYING TO FIT A DUMP VALVE ON MY 96 SMALL TURBO ESC COS IVE TRIED TWO TYPES OF DUMP VALVE DIAPHRAME & BAILEY PISTON TYPE BOTH VALVES GIVING SAME PROBLEMS BLACK SMOKE / STALLING AT EVERY JUNCTION AND EVERY TIME YOU PUT THE FOOT DOWN BACK FIREING. AS SOON AS YOU TAKE DUMP VALVE OFF CAR RUNS GREAT AGAIN. ANY HELP WOULD BE GREATLY APPRECIATED.
Old Jul 12, 2004 | 02:55 PM
wimwerf's Avatar
wimwerf
Hello Gerry,
Relax man.... your escos is the one with the small turbo conversion. you have to look at the inlet hose of the turbo. between the hose and your airfilterbox there is something coneccted isn't it. in there is a sensor which is the problem to this. what you need is a bailey dv with two piston's inside so the engine can't suck false air through the dv like you have now.
best regards.
Old Jul 12, 2004 | 03:06 PM
Gerry Mac's Avatar
Gerry Mac
THANKS MAN ILL GIVE IT A SHOOT CUS ITS SINGLE PISTON TYPE I AVE NOW ILL GET MY HANDS ON THE TWIN . WHERE DID YOU TAKE YOUR FEED PIPE FROM WHICH CONNECTS ONTO TOP OF DUMP VALVE
THANKS AGAIN
Old Jul 12, 2004 | 03:08 PM
wimwerf's Avatar
wimwerf
this has to be a vacuüm hose from the inlet manifold
Old Jul 12, 2004 | 03:15 PM
Gerry Mac's Avatar
Gerry Mac
THANKS PAL JUST CHECKING CAUSE IVE TRIED EVERYTHING ELSE ILL GO AND GET ANOTHER DUMP VALVE
Old Jul 12, 2004 | 03:58 PM
Andymancos's Avatar
Andymancos
look on ebay for twin piston dumpers mate cheap as chips
Old Jul 12, 2004 | 07:35 PM
Gerry Mac's Avatar
Gerry Mac
THANKS PAL ILL TRY EBAY
15
Oct 7, 2015 03:43 PM
xrmalin
Sep 13, 2015 06:52 PM
markk
Sep 9, 2015 08:11 AM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
