Zetec Turbo Head Gasket
02-07-2004, 06:47 PM
What head Gasket are the Zetec turbo 2.1 conversion's using ?
03-07-2004, 09:33 AM
500bhp Cosworth in making
i used to use 1900 felpro gasket from burtons
03-07-2004, 10:29 AM
05-07-2004, 09:52 PM
PassionBMW.com Member
16v??? Hell no dont use the CVH gasket!!!
2.0 Focus 3layer Metal one mate!
(Unles its a ZVH, in which case follow Roosie's advicE)
06-07-2004, 10:17 AM
PhilM where do you get these from. The 16V one. Is it a Ford item.
PArt number ?????
06-07-2004, 11:58 AM
Standard zetec gasket is a 3layer metal one.
07-07-2004, 08:50 AM
2000 ford focus one is thicker.
Its a 3 layer steel type and there about Ł30 ish from ford
08-07-2004, 07:33 PM
What is the max boost they will handle???
09-07-2004, 08:19 AM
Its exactly the same style of gasket all the cossie lads use on their high power cars. 500bhp +
It will be good for as much as you can get out of your Zetec.
As Ford uses them as standard their Ł30
The cossie lads have to pay alot more than that as they are an aftermarket item.
09-07-2004, 09:21 AM
Part Number Anyone ????????????
09-07-2004, 10:50 AM
I might go and get one latter, will post a part number up then mate.
Thanks for the info.
11-07-2004, 11:46 AM
Part no: F1308385 300507 Gasket-Cyli 061
Cost a massive............ Ł24.87!!! lol
11-07-2004, 08:52 PM
robnock
21
13-05-2019 05:29 PM
SmudgerByName
52
28-07-2016 06:14 PM
3i Jim
20-11-2015 05:12 AM
Chopshop85
17-08-2015 06:38 PM
turbobill
09-08-2015 05:21 PM
21 ,
felpro ,
forcus ,
ford ,
gasget ,
gasket ,
head ,
st ,
steel ,
turbohead ,
uk ,
zetec
