T3 or not T3
Old Jul 14, 2004 | 11:09 AM
extra13's Avatar
extra13
Default T3 or not T3
I have a T3 from a saff 4X4 i think?
are there any numbers on it that will deffinatly tell me thats what its from?? It also has an adjustable actuator too.
some numbers and stuff here
from the compressor housing
BCC2 A/R 42 M24
from the exhaust housing
DHSG N1 50A80 A/R-48
actuator
94-119 430099-34
Any ideas chaps
Old Jul 14, 2004 | 02:07 PM
wimwerf's Avatar
wimwerf
look inside the compressor housing. if the inlet is flat it will be a 4wd compressor housing. if there is a sort of little restriction than it will be a 2wd t-3. or am I wrong.
Old Jul 14, 2004 | 02:23 PM
extra13's Avatar
extra13
Ah yes there is a little step just before the compressor wheel, the compressor housing does seem a little small compared to the exhaust housing?
Is this a common swap for cossies?
Old Jul 14, 2004 | 02:53 PM
wimwerf's Avatar
wimwerf
so there is a little step up. I guess you have a 2wd compressor housing.
but what do you mean a common swap
Old Jul 14, 2004 | 03:03 PM
extra13's Avatar
extra13
i was told it was a 4X4 T3 but i guess the whole thing is a 2wd turbo
oh well this will have to do, what kind of reliable boost can i get with a 2wd T3, with a -34 actuator?
thanks for the help by the way
Old Jul 14, 2004 | 04:20 PM
2001ode's Avatar
2001ode
Steve,
If exhaust housing in is fitted with 4 studs, it's 2 wd TC
If exhaust housing in is fitted without 4 studs, just 4 holes, it's 4 wd TC
Regards.
Old Jul 14, 2004 | 05:08 PM
extra13's Avatar
extra13
Thanks guys, its a 2WD TC
Old Jul 15, 2004 | 02:12 PM
wimwerf's Avatar
wimwerf
reliable boost...depends on the condition of the turbo. but you can boost 16psi- 18psi safely.
