Left/Right Play in Steering Column
Old Sep 9, 2008 | 01:50 PM
dunketh's Avatar
dunketh
Chief Iron Oxide Farmer.
Default Left/Right Play in Steering Column
As title, in my mk4 esy.
Any ideas?
No wobble under braking or bumpy roads just noticeable play when turning either left or right.
You can turn the wheel a degree either direction then 'clonk' then it starts actually turning the wheels. Its almost as if one of the CV joints in the column is worn.
Anyone have any ideas? I'm guessing its not column bushes as the column doesnt move itself if I try to wobble it.
I cant see any obvious wear or feel any play in any front joints.
I do have a spare rack if necessary but its for a mk3 if it makes any odds.
Old Sep 9, 2008 | 02:32 PM
Cozziekid's Avatar
Cozziekid
The rack should fit mate, it could be play in the rack itself. Also check the rack mountings on the bulkhead.
Old Sep 9, 2008 | 02:46 PM
dunketh's Avatar
dunketh
OK cheers.
My thought was also to replace the rack just to eliminate it from my list of possibles.
Just wanted to see if anyone had any other ideas.
Its always the little stupid things that are the most annoying.
Old Sep 9, 2008 | 04:17 PM
xrmalin's Avatar
xrmalin
just check the thread pitch on the mk3 one matches to the track rod ends that you have as i think the mk3 one had a slightly coarser thread than the mk4 one.
tankybaby66
Feb 6, 2016 02:24 PM
IainRS1700T
Sep 25, 2015 06:44 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
ST-170
Sep 4, 2015 11:02 AM
