saff 2wd misfire
hi can anybody help me please ive got a 2wd saff stage 1 tune seems to have developed a misfire just under 1 bar boost
i have put new plugs in its not so bad now but still misfires a bit further up the revs.At a guess i,d say its the ignition coil but not 100% sure feedback would be much appreciated thanks
What plugs are you using ?, if you have not already fit a group a coil, as with this and some AGPR12PP8 plugs you will find it drives much better, especially low down.
It could also be leads if a bit dodgy.
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
