help with new cossie
Old Sep 6, 2008 | 04:49 PM
gazm's Avatar
gazm
Question help with new cossie
Hi all - I have just bought a 75k 1995 escos, a just needs finishing type project and needa little help - 4 owner all original never painted etc .The car has a brand new from ford lump in done about 2000 miles, with turbo - all as standard apart from an uprated head gasket. it has 803,s in and a K &N Filter, and some one in the past has removed the air con system . the rad and the cooler and all pipes are out of the car when collected and I want to know if the standard rad and cooler will be ok or should I uprate, and dont know wether the fuel pump is standard , it also has weber marelli autronica ecu in - not the original ford one. I also want to change the discs and pads too. Will get some pic on asap ...anyone help ?... ta
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
