what oil
Old Mar 6, 2004 | 12:26 PM
Default what oil
What oil should i use in my 2wd cossie. Will using the wrong oil cause it to burn more?
Old Mar 6, 2004 | 12:51 PM
swerv's Avatar
swerv
i use castrol rs 10/60
some people use mobil motorsport 15/50
valvoline 20/50 is a good oil as well
using the wrong oil can cause you to burn it yes , but i read your last post and i dont think the oil is your problem matey , wait for more opinions though if your not sure or just pm one the tuners on here , they will help you out im sure
Old Mar 6, 2004 | 12:59 PM
if it is my piston rings whats it likely to cost? Or what else might it be and whats that likely to cost. Im starting to get quite worried about my wallet
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
