xr2i 16v tuning
Old Feb 8, 2004 | 12:47 PM
Default xr2i 16v tuning
hey guys, would a kent cam kit do me any good in performance wise and if i got it would i need to change it again if at a later date i wanted to put an rs1800 ecu in?? can the 2.0 mondeo throttle bodies go on with out any other mods and how hard is it to fit? is the rs1800 ecu the only one like it or will the 130ps 16 scort cab do the same job. what are your views on power boost valves is it best to get one when the cams are uprated? and finally my clutch is low bitting and crunches when goin into reverse but only when the engine is warm?????? i have been told it needs adjusting, this model did come with a cable clutch didnt it???? i do apologise i have just made the swap from a supra to a festa so i dont no much about these lil pocket rockets, oh mine has a superchip as well if that helps you guys with helping me,, thanks fellas
Old Feb 9, 2004 | 12:34 PM
Dave Henshall's Avatar
Dave Henshall
the rs1800 throttle bodys and cams will fit, these will allow more airflow which will be detected by the ecu through the MAF sensor and sogive it moree fuel.
Ian1964
12
Jan 26, 2021 11:57 AM
A.t.p
Sep 29, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
Andypandy260
Sep 23, 2015 10:28 PM
liamT74
Sep 23, 2015 10:24 PM
