4x4 rear crossmember bushes
hi there, stripped the rear crossmember assembly and the bushes need renewing.
it is the 2 large ones that bolt into the floorpan.
where can i get this done in and around derbyshire?
You can do them yourself if you want. Get some powerflex ones. To get the old ones out you drop the arms, put a large socket or similar in between them and the body and lower the car on to them (with the arms on axle stands) fitting the new ones is similar, just put them in place and lower the car onto them, the weight of it drives them home.
HTH.
Iain
HTH.
Iain
HTH.
Iain
HTH.
Iain
03-11-2015 05:08 PM
track.focus'd
12-08-2015 06:53 PM
