step by step strip down (headgasket job)
Hi chaps
Im struggling to get help on attempting to do a headgasket on my 2wd saff, my luck is usually shite ! so im trying to avoid it having to go to a garage just in case it is worse than just the headgasket gone ? As then i will be pretty much commited to them etc. So is there any step by step method documented anywhere ?
any info very much appreciated
cheers mick
cheers mick
Not sure if thare is anything on this site but lots of cos people about all in all its the same as most cars get a haynes do the step by step bit get new bolts if need be do the valve seals and lap the valves clean the comp chambers and pistons and most of all take your time and once done turn the engine by hand at least 2 revs .
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
