efi problum? help please?
Old Jan 19, 2011 | 08:10 PM
crighton13's Avatar
crighton13
Default efi problum? help please?
Hey folks workin on a efi 1600 na and its sparkin but its sparking first and forth cylinders at the same time and second and third goes at the same time aswell. But first and forth spark 3 times and then second and third spark once! Any help please?
Old Jan 19, 2011 | 11:47 PM
cozi500's Avatar
cozi500
what loom you using, if your your using N/A engine you shouldnt use an EFI loom, as this is for injection not N/A
Old Jan 19, 2011 | 11:56 PM
crighton13's Avatar
crighton13
it a n/a but a 1600 injection mate its the right loom for the engine
Old Jan 20, 2011 | 05:06 PM
JonathanJ's Avatar
JonathanJ
1 and 4 then 2 and 3 should spark alternately , I would say you might have a faulty coil , the half that does cyls 2 and 3 , it is breaking down and can only muster 33% of the HT required , as the coil has 1 feed and 2 switched earths , 1 for cyls 1and 4 the other for 2 and 3 , it is sparking at some point so would kinda rule out wiring to some extent ( not completely though )
Try a known good coil first then check wiring continuity back to edis module , then try the edis module itself isthe route i would take .
mk1turboestate
Dec 2, 2015 08:31 PM
liamT74
Sep 23, 2015 10:24 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
