Urgent help
Old Jan 17, 2011 | 07:21 PM
burnhamshaun's Avatar
burnhamshaun
Default Urgent help
On my mk4 e/cabriolet I have a smooth flushed boot with a boot popper rigged up to Clifford key fob opened it yesterday to load some gear in and now it won't work alarm/keyfob works as I've tried both fobs and hear alarm box clicking but no noise from popper so I'm guessing wire must of come of when I shut the boot :-( how the hell am I gonna get it open I have subs behind seat even if I could get the back seat open but I can't due to it been locked in place any ideas peeps
Old Jan 17, 2011 | 07:24 PM
RichieST's Avatar
RichieST
Is there a cover over the inside of the boot? If not then get a big hole cutter, cut through one of the rear lights then reach your arm through and pull the popper, have seen it done this way before, will cost you a new light though!
Old Jan 17, 2011 | 07:35 PM
burnhamshaun
Year there is a metal bulk head/parcel shelf with no holes
Old Jan 17, 2011 | 09:01 PM
burnhamshaun
So if I drill through the light lens what do I do about the light bulb holder and bulbs will this just push into the boot of the car
Old Jan 18, 2011 | 02:09 PM
burnhamshaun
Gonna give this a go tonight
Old Jan 18, 2011 | 03:50 PM
RichieST's Avatar
RichieST
Should do, it wasn't on an escort cab I saw it done though so I have no idea about the set up. It should be done as a last resort measure really, and only do it if you feel confident about doing it, wouldn't want you fooking something up!
Old Jan 18, 2011 | 07:04 PM
burnhamshaun
Well I've now got replacement lights so will give this ago tomorrow now as it's a bit late and I need a cutter
DaveN
13
Jan 9, 2005 06:19 PM
R4N SS
Jan 1, 2005 12:17 AM
Walshy
May 14, 2004 01:34 PM
