one for the MOT testers, testing a track car?
can you smell purple?
Location: normally dewsbury west yorkshire, but i could wake up anywhere!
hi guys and gals.
im currently re-building this estate to use on the road so its gonna need mot'ing
its now fitted with some rs2000 front seats with seat belts
pass or fail on the following?
no rear seats or seat belts?
no air bags or air bag light?
in interior door mechs, windows dont go up or down, the door can only be opened my using the outer door mech from the inside?
plastic windows?
anything else i can think of ill post up.
oh and whats the score with driving to the mot station? its got no tax either but will be insured, cant get a tax without an mot, legal or not?
plastic windows?
no rear seats or seat belts? Not a problem
no air bags or air bag light? Not a problem
in interior door mechs, windows dont go up or down, the door can only be opened my using the outer door mech from the inside? PROBLEM !
plastic windows? Not a problem
Think the door has to be opened from a normal seated position and be obvious how to do it to anyone , might get a friendly tester but he might get bouncy at having to grapple to get it open , can you not set up a simple pull wire like the original early mini had ?
thanks,
was thinking about taking the front windows out for the test so can be opened easily from by reaching out and opening the outer handle
or fitting a pair of proper doors and fitting them for the test.
competant bodger
the doors have to be easy to open from the INSIDE you cant tell the tester to reach out and open from the outside
some testers can be funny about no rear seats and seatbelts if vosa still have it listed as being a 5 seater but being a tester myself i would let that go
so a door change it is then.
im trying to source some cheap door so i can refit the mechs and proper windows
id ahve to cut and reweld the mechs and frame in as the paint isnt a standard silver and then theres the vinyl/liverie to consider.
cheers for the intel fella
as said already , seats are not an issue and cant be failed if not fitted
as for seat belts you can also have harness fitted for mot as long its type approved or has "E" number
plastic windows dont matter as only the windscreen is a testable item
front doors need to be opened from inside and outside , dosent say you need to have original handles though
not a requirement that the windows open , not tested , only the drivers view of the road so must be able to see 2 mirrors
front windows dont need to open for the test
as for the doors, as long as its obvious how you open them for inside the car, it shouldnt be a problem, as the reason for rejectoin is "unable to open from the inside"
just bung a lenght of string from the door latch mechanism that went to the interior handle and lay the string in the door
nothing about checking the belts for approval, but should really have a seat belt installation check if you havent used original seatbelt mounting points
Okay, what about these brake lines? Before i start to bleed rhem.
Is it a problem that theyre looped?
would never loop brake pipes , not not MOT issue but for bleeding issue , it can be a pain to get air from the loop unless you use a pressure bleeder
all cured with the brakes
not far of ready for the mot just need a n interior handle and a change of tyres as there too wide
JoeyBoyden
04-01-2024 02:36 PM
RIB1122
13-08-2015 09:09 PM
track.focus'd
12-08-2015 05:53 PM
