battery warning light coming on
Old Jan 19, 2011 | 07:28 PM
ggordster's Avatar
ggordster
Default battery warning light coming on
Hi, I have recently bought a focus 1.8 tdci 2004 86K i noticed it didnt start too well first thing in the morning so i took it back to the garage where i had bought it from who done a fault reading on it and came up with the following:-
p0100 mass/volume air flow circ error
p0622 generator field f ctrl circ error
p1632 smart alternator fault sensor
All of which were supposedly fixed. I found the can started alot better and the car was alot more responsive so i was happy.
Its been a week now and gradually the morning start up problem has returned although it is fine after the initial start as you can turn the ignition off straight away and start it again and it will fire up straight away so im not sure why this is?
Another problem is at any point whilst driving the battery light comes on and stays on till you turn the engine off and then when you turn it on again the battery light will go out. This can happen after 10 seconds of driving or 30 mins.
I have had the alternator reading on the digital dash running whilst driving and it was between 13-14v until the battery light came on then it when down to 12v and then i stopped and put the fan on radio lights etc and the reading went down to 10v dont know if this is helpful?
I have read that these cars need a calcium battery but i have noticed mine is a regular lead battery could this cause a problem?
Any advice will be welcome as i am very confused
Old Jan 19, 2011 | 07:49 PM
iansoutham's Avatar
iansoutham
OCD Victim
You need a Calcium battery with the smart-charge systems on newer vehicles.
Lead-acid ones are not recommended in this instance.
Old Jan 19, 2011 | 07:53 PM
steve4i's Avatar
steve4i
check the wiring to the alternator prone for rotting out same as the connect's the battery wont loose charge but it puts the battery lamp on
Old Jan 19, 2011 | 08:00 PM
ggordster's Avatar
ggordster
thanks for that do you think the battery will need changing as its not a calcium one?
Old Jan 19, 2011 | 08:09 PM
steve4i's Avatar
steve4i
if its not affecting charging power or voltage problems i would just leave it its upto you tho
Old Jan 20, 2011 | 08:52 AM
martysmartie's Avatar
martysmartie
You NEED a Silver Calcium battery, using a lead acid will cause problems and it is actually dangerous to so as the battery can explode as the silver calciums are charged at a higher rate.
The battery is NOT charging this is why the light is coming on and is reflected in the fact the power drops to below 10V!
Martin
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
dojj
15
Aug 18, 2015 08:21 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Neatrags
Aug 16, 2015 07:57 PM
Dazts1
Was It You?
Aug 2, 2015 06:44 PM
