How do you adjust scorpio idle?
Old Feb 21, 2011 | 09:25 AM
XR_Cos's Avatar
XR_Cos
Default How do you adjust scorpio idle?
Ive just fitted a scorpio engine in my sierra with rs2k ecu and injectors but its idling to high, using scorpio manifold and throttle body, whats the best way to adjust it? If i can?
Old Feb 21, 2011 | 08:04 PM
martysmartie's Avatar
martysmartie
It's likely to be controlled electronically so via the ISCV, I doubt if these have a mechanical base idle that you can adjust. Unplug the ISCV and see if the revs drop, other than that there may be an air leak.
Martin
Fezman1
Oct 2, 2015 01:22 PM
fordrallycar
Sep 30, 2015 07:57 PM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
