Irregular Boost Levels
Old Jan 30, 2011 | 08:37 PM
Rogeyboy's Avatar
Rogeyboy
Default Irregular Boost Levels
What would cause my car to boost differently all the time... Its got a brand new turbo and -31 actuator.
In 5th gear from 80mph it boosts at 1bar but drops off, then slow down and build boost up again and get nothing and then try again and get .5bar max but it holds.
Could the actuator be faulty or the wastegate in the turbo elbow?
Old Jan 31, 2011 | 09:28 PM
Rogeyboy's Avatar
Rogeyboy
Any ideas?
Old Jan 31, 2011 | 09:37 PM
Camel Fiddler's Avatar
Camel Fiddler
Resident Camel Stalker
Could be something sticking and not releasing or holding properly maybe? Could be worth checking actuator or wastegate over.
Old Feb 1, 2011 | 06:59 AM
chaffe's Avatar
chaffe
Turbocharging Technician
does it have a DV?
Old Feb 1, 2011 | 11:45 AM
Rogeyboy's Avatar
Rogeyboy
No DV... I thought maybe wastegate sticking open in the elbow.
Would a boost leak behave like this?
Old Feb 3, 2011 | 07:01 AM
Rogeyboy's Avatar
Rogeyboy
Check for boost leaks, found none...
The wastegate in the exhaust elbow was sticking open tho, so changed that for a different one and its better, but still not quite right!
Boosts more in 3rd, peaks at 0.5bar and holds 0.25, 4th and 5th don't peak they just hold 0.25bar...?
Old Feb 3, 2011 | 01:03 PM
chaffe's Avatar
chaffe
doesnt sound like the actuator is strong enough at that boost pressure, thats only 3.5 psi! it needs to be three time that if not much more! tighten (shorten) the actuator rod quite a bit and see how you get on
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
