escort leaking sunroof ?????
Old Dec 3, 2012 | 07:29 PM
ford123nut's Avatar
ford123nut
Default escort leaking sunroof ?????
Hi all can anyone help! I have a 1998 escort 3 door and every morning when it rains heavy the passenger seat is wet and a steady drip is coming from the sunroof area. The car is steaming up also probably down to the damp seat does the sunroof need replacing or is it some other issue thanks all
Old Dec 4, 2012 | 02:18 AM
johnnysash's Avatar
johnnysash
Could be a blocked channel in your sunroof drain holes. Poke some cable down it to clear it out. Good luck
Old Dec 4, 2012 | 05:12 AM
STeve's Avatar
Super Moderator
as above or it may need a new seal easy to replace and most breakers have escorts in
Old Dec 4, 2012 | 11:28 AM
ford123nut's Avatar
ford123nut
Thanks ill have a look if it ever stops raining
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
3dr cossie
Sep 2, 2015 08:58 PM
Bighandsuk
Sep 2, 2015 05:23 PM
