Workng out the compression ratio on an RS
Hi all,
Just wondered if someone could tell me how to get the compression ratio of my RS engine. The head on my RS has had 0.5mm taken off it which suggests it has been skimmed once or twice so I need to know if this is the reason as to why the pistons have cracked.
Dave
Dave
Yes but the boost was turned right down due to me wanting to run the car in properly. I did about 400 miles in the car when I noticed it wasn't quite right.
Dave
Dave
sounds like damage from detonation. a skimmed head as you know will give a higher compression ratio which generally means that you must run less ignition advance for a given boost. if the chip that you had fitted had quite an aggressive ignition curve that no longer fitted the compression ratio of the engine, or low octane fuel was used, you could've been getting detonation.
the way to measure it is just the same as any other engine. you need to measure the volume of the piston bowl, the combustion chamber in the head and the dead volume and work it all out. there some helpful stuff out there on the net that explains it in general terms.
If I were getting detonation would I here the engine pinking?
The ecu is from a standard S1 RS. Would this effect it?
Thanks for the advice so far.
unlikely that you would hear detonation as it would be happening on boost when there is normally too much noise from turbo, induction, exhaust etc.
but you say you weren't running much boost?
As far as know it sounds like a peice of metal rattling around in a tin. Never heard detonation before though so I could be wrong.
Dave
Dave
