Wiring fault on 3DR
Old Oct 24, 2004 | 07:10 PM
simonc's Avatar
simonc
Default Wiring fault on 3DR
Car cut out tonight 2 times each for a split second, all the warning lights came on & were flashing away whilst i was still driving. When i use main beam for the 1st time on a journey it always causes the engine to jolt/miss as you flick the main beam on & alternator light glows on main beam. Also noticed the headlights on the interior car display thing that tells you if the boots open etc, the headlights on it fade in & out sometimes & also they flash on & off with the indicators. Also as you crank the car over to start it the rev counter bounces all over the place. I'm sure all the above is linked to a dodgy earth somewhere.
Need to get this sorted before i get car mapped
What do you think ?
Simon.
Old Oct 24, 2004 | 08:48 PM
velocity's Avatar
velocity
sounds to me like you have earth problems check all the earths,battery,plenum earths.there is also some down by the front headlight units in the engine bay check them aswell, also the big earth cable bolted on to the engine from the battery negetive terminal
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
martynhomer01
Oct 1, 2015 12:05 AM
