good strong clutch/plate
Old Nov 4, 2004 | 06:39 PM
leecavturbo's Avatar
leecavturbo
Default good strong clutch/plate
i have clutch slip in third and onwards when using nitrous "huge torque" so its the pressure plate not been strong enough rather than the clutch but could be wrong!
any help from you ford boys?
respect to the yb btw
Old Nov 17, 2004 | 12:40 AM
blaazer2's Avatar
blaazer2
you need a paddle clutch then, or if it is a 2wd cossie fit a transit pressure plate , they bolt straight on and are stronger,
Old Nov 17, 2004 | 01:42 PM
2001ode's Avatar
2001ode
Very interesting, Blaazer.
Have you finis code of this Transit clutch ?
Thanks by advance.
Old Nov 19, 2004 | 12:22 PM
2wd's Avatar
2wd
is that correct ? ..... how much stronger will it be than the std.
markk
Sep 9, 2015 08:11 AM
gingeRS
Sep 4, 2015 06:29 PM
turbowag
Sep 3, 2015 08:07 AM
