cosworth running problem
Old Oct 15, 2004 | 07:20 PM
vinnyd's Avatar
vinnyd
Default cosworth running problem
I have recently replaced my engine with a standard engine no problem, the car will start but wont idle for some reason plus when I take up the revs it kicks smoke out it seems like it is over fuelling as it is not oil smoke, plus it will back fire at low revs, I don't really no where to start??? any ideas anyone
Old Oct 15, 2004 | 08:46 PM
blaazer2's Avatar
blaazer2
check the cam timing first , then check you havnt mixed any plugs up on the loom,its easily done i did it once
Old Oct 15, 2004 | 09:04 PM
Dilly's Avatar
Dilly
Could be your map sensor causing it to overfuel. Check the pipe that goes to it is still on
Old Oct 15, 2004 | 10:30 PM
yogi's Avatar
yogi
hi i have just thought i have a overfueling car and when you say check the pipe that goes to it wat do you mean as i only have a plug plugged into mine no pipe ect
Old Oct 15, 2004 | 10:59 PM
velocity's Avatar
velocity
the map sensor should have a vacuum pipe going from the sensor up to the inlet manifold,its a short pipe about 8 inches long with almost a 90 degre bend at each end,its vital for your car to run.it connects here on the inlet manifold (see arrow in pic) and the other end connects to the sensor
Old Oct 15, 2004 | 11:04 PM
yogi's Avatar
yogi
well myne defo dosent connect to my map sensor is this located on the passenger side inner wing do you have a pic of a map sensor fitted to a car if i remember correctly i think the person who i got the car off has connected the pipe from the bit in the pic above on a t peice to the dumpvalce ect so theres nothing connected to my map sensor apart from the connector plug
Old Oct 16, 2004 | 12:21 AM
Dilly's Avatar
Dilly
there's a pic of a map sensor fitted in your other thread https://passionford.com/forum/viewtopic.php?t=79357
Old Oct 16, 2004 | 05:09 PM
vinnyd's Avatar
vinnyd
i had thought about the map sensor, but it wont tick over do you think it could be the cold start sensor ? i have now disconnected the pipe from the top of my dump valve and it will just tick over but still over fueling.... i might just blow the f***** up...
Old Oct 16, 2004 | 10:23 PM
Stu @ M Developments's Avatar
PassionFords Creator
If the map sensors failed its unlikely to idle correctly due to the excess fuel.
Old Oct 17, 2004 | 09:15 AM
vinnyd's Avatar
vinnyd
Default engine problem
stu but why will it idle when the pipe is of the top of the dump valve..
Old Oct 17, 2004 | 11:56 AM
The extra air is leaning off teh excessively rich mixture and moving teh load site nearer to 1 bar absolute in teh fuel map.
manuel boeckx
13
Oct 3, 2015 02:29 PM
kosienutter
31
Aug 22, 2015 09:55 AM
41
Aug 21, 2015 06:47 AM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
