S2 RST Problem
Old Oct 17, 2004 | 02:30 PM
K18NEO's Avatar
K18NEO
Default S2 RST Problem
Ive recently had a convertion from the 1.4 cabriolet, to the rsturbo s2.
Ive fitted a dump vavle, boost gauge, and boost controller. Its not boosting above 2 psi... on the gauge.
Any Suggestions? Im buying a full set of samco hoses tomorow, so anything else?
BTW>.. turbo spools, it dumps, just not very loud. You can feel the turbo, just not aggressivly.
Old Oct 17, 2004 | 02:43 PM
davidnormanuk's Avatar
davidnormanuk
Have you checked you actuator. You can raise the boost by adjusting that. Check you pipes that go to the amal valve.
Dave
A.t.p
Oct 23, 2015 07:54 PM
DAZZER
Sep 30, 2015 08:43 PM
A.t.p
Sep 29, 2015 05:04 PM
