Smoke signs....
This morning on the way to work, when i spun the turbo on my cossie up for the 1st time after warming the car up for about 5 miles... there was a mish mash of smoke/smog... no real colour definition a bit of grey/blackish maybe smal hint of blue... Doesnt do it again, only 1st time the turbo is spun up...
I have noticed this before but not for a while!! Is it normal - just clearing the system.... It is not smoking when i rev it when i get to work!!??
Any ideas??
Any ideas??
I have the same problem. I think its the oil stem seals on the turbo (leak when left overnight)
I had the same prob before, but it disappeared when i swapped the turbo for another one (pity it appears to b headin the same way)
this is nothing to worry about really, it is the turbo oil seal , as above, weeping through slightly when switched off and its not until u give her a bag full of boost that it 'clears her throat', as long as it is only once and it is not putheing out when on boost once hot.
Steve Escos
Oct 1, 2015 06:57 AM
