Cossie misfire ......
Old Nov 4, 2004 | 07:11 AM
2wd's Avatar
2wd
Default Cossie misfire ......
Hi...My old 2wd Sapp. has a very bad habbit of starting a misfire when it come on boost...starts around 20 psi , for example it would appear in 2'nd gear and nothing in 3'rd, and next time it gone or happens only in 3'rd .....
The car runs a Ahmed Bayjoo 330 setup.
Problem is that it comes and goes from day to day so it's quite difficult to check it, could be gone in a month and the back for a week and so on ... I have tried different (Denso and Champion) plugs with gabs ,5 to ,8 mm and it dosent matter....sometimes it misfires and sometimes it dont
When going "normal" and not hitting full boost, all seems to be ok.
Old Nov 4, 2004 | 04:27 PM
alan rainbow's Avatar
alan rainbow
HT LEADS i had this problem fit some new standard beru leads there a bit pricey
Old Nov 4, 2004 | 04:48 PM
2wd's Avatar
2wd
Hmmm....the ones I have are only a few years old ..... and are the blue silicone "ford Racing" ones..... could they already be "dead" .
They have max. done 25000 miles...
Old Nov 4, 2004 | 05:59 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Does the Finis code read 909 ? In which case I think they are ok, there are some other "blue ford" ones that are not too good.
Erm, changing your leads to BERU won't necessarily fix it either, it may, it may not. I have Beru's AND a misfire - so before you throw nigh on Ł200 at new BERU leads, I would make sure everything else is ok.
Considering it's on an off (the misfire), you could have a dodgy electrical connection somewhere ?
Old Nov 4, 2004 | 06:14 PM
2wd's Avatar
2wd
Ok and thanks...I will check if they read 909.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
