TPS voltages on 2wd cos
if your not sure test it yourself ,eg map sensor same voltages idle 1v full presure 5v ,thats how ecu take readings on any car,hope this gives you more help i can give you reistance readings for it if you want
ps, sorry your right i was thinking you had pfo9 4x4,as 2wd work back to front,the resistance is 1000 ohms to 3000ohms approx
Originally Posted by frog
Steve, I will check for you tomorrow, too cold, dark and wet out there at the moment.
cit-tech,
i could test it myself but the problem is i think its not adjusted right so need the correct measurements so i can adjust mine to them, cheers anyway
Originally Posted by alan rainbow
2wd 5volts at idle and 0.5 volts full throttle
Just been out in the cold and dark and measured it on mine - 4.99 at idle and 0.43 at full throttle.
That's measured with the ignition on (engine NOT running), between pin 17 on the ecu connector and the ecu body itself.
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
, i've now been told idle is 4.5-5v and full throttle is 0.5v.
