what engine oil for a cosworth
i've just rebuilt my engine and it's going for mapping soon
so i'm going to change the oil
what grade should i use
i was using mobil motorsport 15/50
the car will be running approx 400 bhp and doing alot of trak days
thanks biscuittin
thanks biscuittin
if it is just rebuilt i was told to use a very low adjative oil. There are some special oils for the job, I beleve that mobil and othe new designed oils can cause bore wash on a fresh engine,so its has to be run in for a 1000m
Originally Posted by cng1
Where is the best palce to get the RS from? Most places that I've tried seem to either charge silly money or not be able to get hold of it.
_________________
ML Developments
07743 661187
07765 610550
Cannock, Staffs
I think you will find that Matt @ML will do you a very acceptable deal
big_Rad
Sep 15, 2017 09:36 AM
JoeyBoyden
Aug 18, 2015 10:52 PM
Aug 14, 2015 07:29 AM
