Enigine stall after boost
Old Dec 31, 2003 | 10:18 AM
Default Enigine stall after boost
Hello everyone, im new here so i'll let u know what the car is running first to help you solve the problem, if you can.
At the moment, mahle low comp pistons, stage 1 head, stage1 turbo technics turbo, piper fast road cam, 16psi boost, all performance plugs leads etc. 195 chip. 160bhp.
Now i think the car is over fueling as when i boost up in it, say in between speed bumps, then dip the clutch back in when stoping the revs fall right down and somtimes the engine cuts off all together. the more i boost up the more the chances are it will cut off. I also get a really strong petrol smell and the car only does 70 miles to £20.
With the mods done so far, would i be right in thinking it should be running around the 180bhp figure?
I had this problem on my last rst and always thought it was the dump valve. the only other problems i could think of was a vacume leak in one of the pipes.
I was reading somewhere thou, to disconect the pipe from the turbo to the actuator and plug it of the turbo end, then plum a new pipe in from the actuator to the charge carrier pipe.
Any ideas on what might be the problem?
cheeRS
skeld
Old Dec 31, 2003 | 10:33 AM
Stu @ M Developments's Avatar
PassionFords Creator
Have you got a dump valve on it?
If so, take it off.
Old Dec 31, 2003 | 10:41 AM
Yeah its got a dump valve. Reckon this is the problem? How come so many other rst owners manage to run dumpvalves without problems?
Old Dec 31, 2003 | 10:49 AM
Sounds like yours is faulty.
If its the correct type, the 2nd piston may be sticking.
If its a diaghragm type, its wrong anyway and WILL cause these problems.
Let us know the outcome please to help others.
Old Dec 31, 2003 | 11:00 AM
its definatly a twin piston, ive had problems with dump valves sticking before, sticking that bad that they didnt even dump. I took them apart and oiled them up a little with bike chain oil (only oil i had lying around)
I'll try it on this one and let you know how i get on. Ive heard of a few people having this problem so hopefully i'll be able to solve it for everyone.
Old Dec 31, 2003 | 11:10 AM
Dont try oiling it mate... cut to the chase.. remove it from the car completely.
DONT just pull the top pipe off, as this doesnt help with these symptoms..
If the problem goes away, then of course you can try to overhaul it.
Old Dec 31, 2003 | 12:56 PM
Gav Diamond's Avatar
Gav Diamond
As stu said remove the dump valve all together as i had a problem like this with my old rst
ok mate. i'll do that and see what happens. im 90% sure it has got somthing to do with the dumpvalve tho, cos my last rst did this but stopped as soon as the dump valve got stuck closed.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
