smoking erst
Old Jan 18, 2004 | 05:29 PM
Default smoking erst
help my escort smokes when it is up to temperature or when comes on boost does any one have ant ideas
Old Jan 18, 2004 | 06:30 PM
flashpoint's Avatar
flashpoint
Could be one of the following, turbo oil seals, valve stem seals, blocked turbo oil return pipe, or engines wear?
Dose it smoke when you first start it? How many miles has it done?
Steve.
Old Jan 18, 2004 | 09:49 PM
it has done 95k not sure about turbo but valve stems done in 02, the engine un sure about but runs sweet as a nut
Old Jan 18, 2004 | 10:06 PM
does in blow smoke when under load or when you back off and are on overun?
if its under load probably guna be your turbo
if it does it when you lift of then its guna be valve guides or stem seals.
Old Jan 18, 2004 | 10:25 PM
cheers its when your on full throttle and when its hot
Old Jan 18, 2004 | 11:12 PM
mmmm im afraid that if it does it when your foot is hard down that sudgests that your turbo is blowing oil im afraid mate
this is of course presuming the smoke is a blue colour?
if its black smoke then its overfueling which would probably mean a faulty engine sensor.
Old Jan 19, 2004 | 09:12 PM
cheers mate got a new turbo anyway
Old Jan 19, 2004 | 10:43 PM
cool me too, a dirty gurt big un!
Mc5506
Oct 5, 2015 09:57 PM
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
A.t.p
Sep 29, 2015 05:04 PM
