cossie ecus
Old Jan 7, 2004 | 10:55 PM
Default cossie ecus
what is the best ecu to run on a 2wd cossie and how can u tell which is which
Old Jan 8, 2004 | 01:16 AM
SPADGE's Avatar
SPADGE
A lot depends what stage of tune you are aiming for really?
If you are starting with nothing then a level 8 would be the best one for you to get as it has a greater capacity for future mods! Although a Level 6 (standard in a 2wd Saph) would be adequate.
Level 1 - small yellow mixture screw and brackets
Level 6 - larger white mixture screw and brackets
Level 8 - white mixture screw and no brackets 2wd = red label
Level 8 - as above 4wd = Green label
The above is the general way to tell the difference but a check of the numbers on the covers would also be a good idea!
HTH
Spadge...
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
