bleed valve or amal valve
help my cossie is running a hyrid t35, greens,k&n,magnex exhaust,3bar map sensor,chip,bd10 cams,20psi boost
I want to know if i can run it just on a bleed valve or if i have to have an amal valve
please help
please help
depends on the chip mate.
If the chip "uses" the amal valve then you'll need it, if it don't then you don't.
Best bet is to take it to your tuner/whoever set the car up.
I run mine with a bleed valve no probs
I've just pleloaded the actuator quite alot so that the boost doesn't spike to much, i'm runnin 23psi peak 21psi hold
