FRST Being a Bitch, please help!
Old Jan 13, 2004 | 12:34 PM
Default FRST Being a Bitch, please help!
Hey folks can anybody help me with this one?
FRST, OFAB, standard, just been put together after replacing the head gasket!
Car starts fine, idles, revs half way but when you give it full throttle the car gently cuts like its getting starved of air or fuel! If you keep your foot right down the car dies, if you let your foot back up half way it goes fine again!
Im thinking this is a ecu or map or o2 adj or tps problem!!!!!
What I know so far is this - Fuel pressure is fine, compression is fine, spark is fine, all electrical readings seem fine, battery is fine, when tps is disconnected it wont even start, ecu is getting live.
Two concerning issues:
Fuel pump feed from ecu reads +4 volts all the time, even when the car is running!
I put new spark plugs in ran it on half throttle for a couple of minutes, checked spark plugs - fine! I then put the spark plugs in and ran it for a minute on half throttle and tried flooring it, it did its usual, i did this twice then switched it off. Took plugs out and they were black - overfueling!!!!!
PLEASE HELP, PLEASE!!!!
Old Jan 13, 2004 | 12:44 PM
DanS2turbo's Avatar
DanS2turbo
From what you have described, it sounds similar to how my RST went when I put a new head on it. My Spark plugs were shot, just popped some new ones in & it was as good as gold.
Clean the plugs off & try driving it rather than giving it half throttle for a view minutes.
What plugs are you using?
Make sure the car is set to all the std timing marks or it won't run right.
Dan
Old Jan 13, 2004 | 01:26 PM
CraigN's Avatar
CraigN
is it chipped ?
check the connections on the chip and your boost level.
mine did that sometimes on me old engine shortly after it went bang due to running lean
Old Jan 13, 2004 | 01:34 PM
PJay's Avatar
PJay
This could be the problem, is the fuel pump running off this? this feed should be used to switch a relay to provide power to the fuel pump.
PJay
Old Jan 13, 2004 | 04:48 PM
No Pjay the fuel pump is wired through a switch!
Im not using a relay but what I was meaning by the fuel pump feed reads +4v all the time is that if I was running a relay it looks like the fuel pump would be running all the time and hense the ecu is in limp home mode....
Dave.
Old Jan 14, 2004 | 11:47 AM
bttt
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
xrmalin
Sep 13, 2015 06:52 PM
bigryrs
Sep 5, 2015 02:57 PM
rsturbo27
Sep 1, 2015 09:54 PM
bigryrs
Aug 28, 2015 05:32 PM
