Series 1 Rose Joint dust covers ?
Does anyone kmnow where we might get some of these from MOT Failure on all 4 but fords do not list them anymore ?
Dust covers do you mean the gators that cover the rose/ball joints
As long as there is no play they are not an mot failure but if its more hasle than good you should be able to obtain them from a motor factors m8
Regards Doug
Regards Doug
hi mate it is where the roll bar attaches to the car (under radiator) there is 2 rubber dust covers at each side all 4 have perished and ford do not sell s are a bit stuck ?
as daz says you cannt buy them either :S
i thought it was a bit much failing it but to an MOT station it looks a bit like a split rubber bush ?
only thing we can think of is getting on of somwhething else the same size :S maybe track rod end as they also have a cover ?
Originally Posted by DazC
You can't get the origional Ford rose joints though!!!
I tried and struggled!!
who said anything about Ford rosejoints?????
I only said you would have to buy some more, i didnt specify they had to be from Fords!!
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
As Martini says, split boot shouldn't be MOT failure, provided there is no play in the joints..
But... obviously better to fix it.. - only thing I can suggest is buy the cheapest track rod ends or replacement balljoints that you can find, from any car that gives you suitably sized boots to rob, and fit on your joints.
Similar problem with Sapph track control arms - when the boot splits you have to replace the arm at £50.. so i've just got a cheap ball joint and robbed the boot and chucked the rest away..
I tried to get rose joints that would fit the arms and still couldn't!!!
Unless you know somewhere esle Scott?
not somewhere but someone... Brom from zoo motorsport
rsguy
44
29-09-2015 03:29 PM
SMILER258
28-09-2015 09:04 AM
