Escort cosworth ABS pump not working
Old Sep 24, 2013 | 02:09 PM
stecozz's Avatar
stecozz
Default Escort cosworth ABS pump not working
Pedal is rock hard with no brakes at all and the pump is dead,checked the main fuse box and the ones in the boot and all are ok.
Could it be a relay?
Old Sep 25, 2013 | 11:28 AM
jon@work's Avatar
jon@work
Could be a relay, but check the wiring and connector on the pump (it's the lowest 2 way connector).
I doubt the fuse is in the main fuse box, so keep looking for a dodgy fuse - I believe the ABS ECU is behind the driver's side rear quarter trim panel, so have a look there for the fuse.
Old Sep 25, 2013 | 05:18 PM
grcossie's Avatar
grcossie
As said before, pressure switch on abs unit
Old Sep 26, 2013 | 09:03 AM
stecozz's Avatar
stecozz
Will check tonight.didnt see a 2way connector at the bottom, will get at it from underneath.
Cheers guys
CabrioTurbo
Aug 1, 2015 11:04 AM
Old ford
Jul 31, 2015 06:50 AM
