Converting to efi
Old Jan 9, 2009 | 08:22 PM
nick8saff's Avatar
nick8saff
Default Converting to efi
What do I need to convert my series one to efi any help will be appreciatted
Old Jan 10, 2009 | 06:01 PM
Toe Knee's Avatar
Toe Knee
ideally what i did with the gfs mk4 cabby and get hold of a mk4 escort efi loom then u dont have to worry bout cut and shut wires all over the place!! then obviously all the extra parts like the ecu, edis module, ISCV etc etc. Also if u wanted to use the same engine then they dont have a hole for the crank sensor in the block so from memory u have to change the pulley for one that has a pick up on it for the edis module/crank sensor to work. I know a mates RS turbo that was converted with an efi turbo engine just had a fiesta turbo loom bodged in the engine bay with live feeds to a few of the wires which althou a bit crude did actually work which meant the original car loom was left which u have to rip out to fit the efi escort look like i did which althou takes time is the better way IMO!
mondeomark
Sep 28, 2015 06:28 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
Neil Clark
Sep 8, 2015 07:06 PM
hopper350
Sep 4, 2015 12:53 AM
