mfi converting 2 efi .. core plug??
Old Jan 22, 2009 | 03:51 PM
Smartdj.'s Avatar
Smartdj.
Default mfi converting 2 efi .. core plug??
does anyone know the size of the core plug which i need to plug up the whole where my dizzy was?
also how do u fit core plugs do you tap them in carfully with a hammer and a bit of sealant?
Old Jan 22, 2009 | 03:53 PM
B16CVH's Avatar
B16CVH
You can get the bung for the dizzy hole from Burtons
https://www.burtonpower.com/product_main.aspx?home.aspx
Yep jus make sure the hole is clean and tap them in, never had any problems
Old Jan 22, 2009 | 04:01 PM
Smartdj.'s Avatar
Smartdj.
ahhh thank pal i did see they do a set of core plugs but i wasnt sure if it would be included in the set..wicked problem solved
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
mondeomark
Sep 28, 2015 06:28 AM
