tapping noise from engine on zetec s w reg
hi guys done a cambelt and oil change on my sisters zetec s, and now it is tapping seems to be coming from the inlet cam area sounds like it has dropped a valve or the little ends.
but it only does it occasionally and when it does it it trys to stall and misses whilst popping back through the inlet.
now it cant be the timing as i have checked this at least 6 times and when running ok it is sweet.
any ideas as im stumped!
deffo not cam timing as im sure they have no key ways etc?
right viscosity oil?(5w40)someone at work put the wrong oil in a zetec it jacks the lifters up!
bottom pully has no keyway same for the cams i very much doubt it is the timing as i have checked and double checked and it is doing it intermittantly if it was timing it would be doing it every cycle
It is a inlet valve sticking, plain and simple, not uncommon at all, though not hugely common on zetec s.
Oil viscosity won't affect it, I would try some WYNN's hydraulic valve lubricant(halfords), althought he problem is outside the valve itself this stuff removes varnish, and carbon well.
JoeyBoyden
04-01-2024 02:36 PM
track.focus'd
12-08-2015 05:53 PM
