zetec tuning
Old Jan 18, 2009 | 09:00 PM
16vzetec's Avatar
16vzetec
Default zetec tuning
can you build a high revving n/a 2.0l silvertop zetec on a budget?
can i skim the pistons down to lighten them and have the rods lightened and a balanced bottom end?!?!?!?
lightened flywheel?!?!?!
obviously arp bolts.
what about oil pump pressure? baffled sump??
also the tappets? can i use black top tappets somehow?
what are the things i would need?
anyone know
Old Jan 18, 2009 | 09:01 PM
rst in breaking's Avatar
rst in breaking
i think you'd be better starting with a blacktop tbh as i believe they have solid lifters, longer rods etc?
Old Jan 18, 2009 | 09:17 PM
16vzetec's Avatar
16vzetec
i agree but i would struggle to get it to fit in my mk4 coz i have all the mk5 escort power steering setup on mine and the black top water pump will get in the way of that!!?!?
Old Jan 18, 2009 | 09:40 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
There's not much point in trying to make it rev higher if the engine won't be breathing a lot better!
Old Jan 18, 2009 | 09:48 PM
16vzetec's Avatar
16vzetec
it will i have throttle boddies!
Old Jan 18, 2009 | 09:56 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You're not going to be revving much higher than stock unless you upgrade the valvetrain.. springs mainly. I think standard rods would be a timebomb, but shot-peening and polishing them and using ARP bolts should extend their range - by how much, who knows.
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
A.t.p
Sep 29, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
