cam timing yb
Old Jan 4, 2009 | 08:11 PM
kaking1982's Avatar
kaking1982
Default cam timing yb
just wondering where the mark on the distributor drive pulley points to when timing the engine
Old Jan 4, 2009 | 08:30 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Hope these ae of some help, copied them off some one on here many moons ago
Old Jan 4, 2009 | 08:36 PM
kaking1982's Avatar
kaking1982
that good mate cheers
Old Jan 4, 2009 | 08:46 PM
louie1's Avatar
louie1
it should point to 1:30 on a clock face and then the rotor arm should point to the cut in the distributor hope this helps you.
Old Jan 5, 2009 | 01:12 PM
The dizzy pulley amrk is irrelavant os long as the cams are timed and the rotor arm is dead in alignment with the scribe mark on dizzy body.
Old Jan 5, 2009 | 08:28 PM
wes's Avatar
wes
What he said.
Look to the right hand side of this drawing where the arrow is, dizzy arm should be centred on this mark at TDC:
Old Nov 27, 2016 | 04:39 PM
dave99's Avatar
dave99
Sorry for dragging this up again but here goes...
I have just changed the belt and tensioner on my 3 door and right enough the dizzy drive pulley was out of line.
I marked the pulley position and changed the belt.
Then I checked the rotor position and it was nowhere near the scribe mark.
I have slackened the belt and moved the centre of the rotor in line with the scribe mark and she starts no problem.
Is it possible for it to run with the rotor away from the Mark? It must have been as I took care to mark the pulleys....
Thanks,
Dave
RUBY123
Oct 22, 2023 12:04 PM
Danielbetty
Oct 3, 2015 06:01 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
taylora1409
Aug 12, 2015 12:06 PM
